Order Ford 3000 Parts Online
Ford 3000 Gas - Ignition Switch Wiring
Bluther
10-08-2005 11:25:36
My ignition switch is out and I bought a replacement at Tractor Supply. My old one is a lucas, 3 blade. Two of the blades have two wires on them and the other has one. The new replacement switch has 4 posts. 1 labeled for starter, 1 for ignition, 1 for battery and 1 post for acces. The old wires aren't labeled and the old switch is only labeled 1, 2 and 3. Any help as to determining what the wire are and where they would be placed on the new ignition switch?
souNdguy
10-10-2005 04:42:46
 Re: Ford 3000 Gas - Ignition Switch Wiring in reply to Bluther, 10-08-2005 11:25:36
Use an ohm meter or test lamp if your old switch is still a bit good. Determine the placement ont he incoming 'power' wire. The rest of the contacts should be sequntially located in order, as you turn the switch. With that.. I would assume 'starter' momentary on is the last position. Second position will have to be ignition power, and possibly dash cluster ( not familiar with 3000 ).. Ignition will need to stay powered while the momentary starter is engaged as well. Shouldn't be too hard to trace / re-wire.
Soundguy
