Order Ford 8N Parts Online
1950 8N HYDRAULICS
RANDY
07-09-2001 14:07:48
BLEEDING DOWN WHEN CLUTCH IS INGAGED WITH BOX BLADE OR ANY HEAVY 3POINT HOOKUP,SHOULD I REBUILD PUMP OR IS THERE A SET OF O-RINGS TO REPLACE?
Bill
07-09-2001 15:40:53
 Re: 1950 8N HYDRAULICS in reply to RANDY, 07-09-2001 14:07:48
What ya got in the old girl is a scotch yoak pump that at times will blow a paper gasket on either side. Doubt the pump is what you preceve to be a problem however. Most of us leave that sort of thing alone but if it's enough of a nucence to ya you efforts would be better served to honing and replacing the rings in the lift cylinder. Your pump it would apear has enough pressure to raize the implement. Once you push in the clutch however it ain't pumping any more and your probably leaking fluid around that worn lift cylinder.
