Order Ford 640 Parts Online
Ford 640 sleeves or no sleeves??
Andy in Ct
10-18-2005 17:02:37
How do you tell if the block is sleeved or not?
Wayne in Iowa
10-19-2005 06:00:44
 Re: Ford 640 sleeves or no sleeves?? in reply to Andy in Ct, 10-18-2005 17:02:37
If the engine was cast for a canaster type oil filter. and probably now has an adapter for a spin on filter,it would have come from the factory with sleeves. If the engine was cast to except only the spin on oil filter, then the engine came from the factory without sleeves.HTH
BruceR TN
10-18-2005 17:13:24
Look for a diamond before (or in some cases after) the serial #. The diamond indicates a sleeved engine.
