Order Ford 600 Parts Online
3600 Diesel
David
07-10-2001 06:59:20
After about 10 hours of use if I let the diesel idle for a few minutes it will go dead and not crank until I bleed the fuel lines. Once I bleed them it runs and idles fine for another 10 hours or so. I replaced the fuel filter and all it orings and seals. I have removed each line from the tank to the injectors and they appear in good condition. No grooves or anything. I have NO fuel leaks anywhere. Does anyone have an idea where the air is getting in?
texadian
07-19-2001 09:55:11
 Re: 3600 Diesel in reply to David, 07-10-2001 06:59:20
David, I guess we're all stumped, here's some brain storming: Diesel fuel seems to have alot more entrained air in recent years; it foams more when refueling; there's advertisements for fuel filters that homogenize entrained air. Could it be that you're accumulating entrained air in a filter and releasing it suddenly into the inejction pump? Have you tried fuel from a different supplier?
