Order Ford 9N Parts Online
1947 Ford 9N power lift
Charles Gill
07-10-2001 12:51:19
I have recentley changed the fluid for the power lift. It has been working great until yesterday. If I put an implement on, the power takeoff will only lift about an inch and a half. Without an implement, it still works pretty good. Can you give me a clue as to what to do to fix this problem? Thank you very much.
Nolan
07-11-2001 06:40:06
 Re: 1947 Ford 9N power lift in reply to Charles Gill, 07-10-2001 12:51:19
Off hand, I'd suspect you've got a problem building up fluid pressure. With the right hand cover off you can check it for leakage, particularly around lift piston and the pump's pressure relief valve.
Salmoneye
07-11-2001 05:13:34
Sounds like the cam-follower pin is buggered up.
Get yourself an I&T FO-4 manual and then post this question on the Ford, N-Board. Those guys will set you on the right track....
Keith
07-16-2001 10:16:15
 Re: Re: 1947 Ford 9N power lift in reply to Salmoneye, 07-11-2001 05:13:34
check the gaskets on the pump itself after you check through the inspection plate. Word of advice--replace of them while you have the pump out. Dummy me only replaced one, and had to go back in a few days later! It is a simple job to do--get your manual out for reference.
