3 pt hitch wont go down
53GoldenJubilee
11-07-2005 12:23:22
Hi all,
On my Jubilee my 3 pth arms will not go all the way down with the postion control lever all the way to the bottom but it will still pick it self up to the highest postion when you pull the lever back up. Any ideas? Is this a common problem? Expensive to fix? Thanks in adavnce for the help!
Dan
11-07-2005 12:33:57
 Re: 3 pt hitch wont go down in reply to 53GoldenJubilee, 11-07-2005 12:23:22
First, make sure your hydraulics selector just under your seat and by the position control lever is in position control and not draft control mode. This lever should be up and down (vertical), not sideways (horizontal) if you want the lift to react to the postion control lever. If the selector is in position control mode, you may need to replace your cam follower pin and adjust the lift cover. I have posted a link to a fellow board members excellent PDF document he put together for step by step information on adjusting the lift cover - with pictures.
Good luck,
Dan
