ford one arm loaders
doug fasse
11-13-2005 08:59:10
im looking for ford one arm loader any boby khow where i might find one?
John O (MI)
11-18-2005 18:00:57
 Re: ford one arm loaders in reply to doug fasse, 11-13-2005 08:59:10
Where are you located, Doug?
I've got a spare trip bucket 711 with brackets for a 600/800 in Michigan that I would sell. I've upgraded to the hydraulic bucket 711 like you see in Soundguy's picture.
-John
CH
11-16-2005 03:14:16
I have one that was on a 800. I am in the North East, Outside of Rochester New York. Bucket like new with manure forks and a cover that slids over them . as matter of fact the whole loader is in nice shape been off for years. Have all brackets I'd take $400. for it all
Ultradog MN
11-15-2005 15:49:32
Doug,
What model of tractor do you have?
They made those one armed loaders to fit a bunch of different Fords. Basically there are two loaders and half a dozen different sets of brackets.
I have a one armed loader that will fit on the Hundred/early thousand series and another that will fit the later 3 cyl thousand series.
I have some brackets but not for every model.
Send me an email if you are interested.
I could help you get things figured out.
Jerry
doug fasse
11-15-2005 16:55:56
 Re: ford one arm loaders in reply to Ultradog MN, 11-15-2005 15:49:32
i have a 600 madel
souNdguy
11-14-2005 12:15:25
Here's a pic of my 722 loader on my ford 660.Is hyd up, and hyd dump, tapped off tractor hyd cover with 2 spools. Works great.
You looking for a 711 ( trip dump ) or a 722 ( full hyd )? ( I'd look on ebay)
Soundguy
souNdguy
11-14-2005 12:20:24
 Re: ford one arm loaders in reply to souNdguy, 11-14-2005 12:15:25
third party image
Pic
Ultradog MN
11-15-2005 15:58:21
 Re: ford one arm loaders in reply to souNdguy, 11-14-2005 12:20:24
Sounder,
I'm about to start modifying the 6' 711 snow bucket to fit on my 722. And I'm going to go back to the true 722 and start running mine off a front pump instead of off the dual remotes. I have the original stanchion with the twin spools that came with the loader but have had it hooked to the dual remotes as it was quicker and cheaper to get it on the tractor.
Jerry
souNdguy
11-15-2005 20:03:05
 Re: ford one arm loaders in reply to Ultradog MN, 11-15-2005 15:58:21
With as little as I use my loader.. I'm leaving mine on the remotes.. though a real loader control would be nice. If I needed remotes for something else, it would also be a reason to do it.. but so far.. i have a 5000 and 7610s, and JD-B with remotes if I need fluid power.
Bet that snow bucket looks nice!!
Soundguy
nw_bearcat
11-14-2005 05:16:54
There was really nice unit in Bethany MO. Don't remember what the guy wanted, $500? came off of a 4cyl 4000.
