Order Ford 6000 Parts Online
1964 Ford 6000 Tractor
Steve
02-04-1999 10:54:38
A little background, I plan on mowing a 6 acre field and rotortilling a 1 acre field, I was wondering if a 1964 FORD 6000 FARM TRACTOR 4 cyl gas eng, frt bucket, has down pressure on bucket, runs gd. $3300, would soot my needs. Is this tractor over priced. I'll also be pulling trees out of the wood for cutting (personel wood).
WHat are the + and - associated with this tractor, or should I be looking at a different tractor...
Any help would be greatly appreciated.
My budget is $2,000.00 - $3,000.00 for the tractor
only, not including implements..
RICK
02-05-1999 17:03:15
 Re: 1964 Ford 6000 Tractor in reply to Steve, 02-04-1999 10:54:38
6000 is a really big tractor, 600 is a really handy tractor. $3300 for 600 w/ loader is not a bad price if everything is pretty good. It's a great price for a 6000 if everything is good. If the tranny is bad or goes bad $3300 for a fix would be a good price.
Rick S
02-06-1999 17:47:21
 Re: Re: 1964 Ford 6000 Tractor in reply to RICK, 02-05-1999 17:03:15
Can We Say OVERKILL!!!!! !! A6000 Would farm a Quarter Section Easy (thats 160 Acres For you city Boys) An thats on weekends only!!!!! !
Rick S
02-06-1999 17:40:00
If its a 6000 can we say OVERKILL!!!!! !!! it would farm a Quarter Section with no trouble !!!! ( that 160 Acres for you city boys !!!!! !)!
Tommy D.....
02-05-1999 11:22:01
Steve,
Better check out the following site:
Link
Read the "History..." section and what it says about those models of 6000.
I've never owned one, but I don't hear good things.
Tommy D.
David Davis
02-05-1999 11:41:02
 Re: Re: 1964 Ford 6000 Tractor in reply to Tommy D....., 02-05-1999 11:22:01
We had two 6000 a 62 and 67 both where diesel(6cyl).Seems like a 4cyl gas is"nt right.Sure its not a 600.The 6000 gave us good service but a few points to look for is hydraulic leaks.The system has a nitro-pressure tank and 3000psi even with engine off it will pick up a 3point 4bottom plow 4times you should always kill pressure when done. Make sure it shifts good (slecto-speed)and rear is not noisie at road speed. Dave
