12v conversion
Walt in VA
07-13-2001 18:05:13
I just bought a 12v. conversion for my 640. I am a little concerned. The kit converts pos. Ground to Neg. Ground and 6v to 12v. How does this affect the starter?
Walt
CRS in AL
07-13-2001 18:51:11
 Re: 12v conversion in reply to Walt in VA, 07-13-2001 18:05:13
Hi Walt.
Dont worry, the starter can't tell the difference which way the current flows or ground is, ( + or - ). That 6 volt starter will crank fine for you. Any time in the future that the starter quits, you can have it rebuilt as a 12 volt.
My 6 volt starter lasted for 15 years before I had to have it rebuilt.
Good Luck ///CRS///
ed
07-26-2001 19:21:26
 Re: Re: 12v conversion in reply to CRS in AL , 07-13-2001 18:51:11
I got more then 15 years out of mine. The engine just turns a little faster and starts better. I think it will actually last longer - less cranking.
Rod MI
07-13-2001 22:30:24
CRS in AL I checked with a couple places around hear and most didn't wont to mess with converting my starter to 12v is there a place you now of that dues good work that you could recommend and do you now what is involved in the conversion dues the windings have to be rewound thanks Rod
walt in VA
07-13-2001 19:04:22
Thanks
Walt
