FORD THREE PT
ANDY IN WIS
11-18-2005 13:04:43
I have a ford 640 and the three point is operating slow it seemed to start when it got cold. I've changed the oil in the hydrulics but doing the same. Now i have to slow the engine to a low idle to make it work. anybody help me?
mowr
11-18-2005 17:44:39
 Re: FORD THREE PT in reply to ANDY IN WIS, 11-18-2005 13:04:43
There are three separate reservoirs for the transmission, hydraulic system and differential. Make sure all of them are up to their proper levels because sometimes the seals that separate them are worn and when the hydraulic fluid is drained, the fluid from one or both of the others drains also. IF one or both seals are bad, you'll want to use tractor hydraulic fluid in all three reservoirs or you'll be getting gearlube into the hydraulic system, slowing it down. Also, when the hydraulic fluid was drained, was the hydraulic pickup screen cleaned? If not, there's a good chance that it's getting clogged; a common cause of slow hydraulics. Good luck. Let us know when you get it solved.
Larry NCKS
11-18-2005 15:39:48
Did you put in hydraulic fluid rather than gear grease? Sounds like time to overhaul the pump if you put in the hydraulic fluid. You could try priming it by removing the hex plug from the front top of the pump, cranking the tractor until oil comes out and replacing the plug. If that helps, but the help is short lived, you definately need a pump overhaul.
