Tire Problem
bottomboard
11-20-2005 08:05:00
Got a tire on my 1956 850 which has a bad tear on the inside...you can see the tube...where do I look for a new tire or possibly a used tire? Thanks..
Farmer Alf
11-20-2005 20:34:42
 Re: Tire Problem in reply to bottomboard, 11-20-2005 08:05:00
Ask about new or used tires at a tire dealer (firestone, michelin heavy truck type place probably not your local K-mart ) They are more likely to have used tires if your 850 happens to use a tire size that is common on the front of newer front wheel assist tractors. Another place you can try is a local tractor wrecking place. It may be cheaper and easier for all concerned to have them leave the tire on the rim, and swap the whole thing rather than tring to do an R&R on a used tire.
BobReeves
11-20-2005 16:30:49
If it's on the side wall you probably will end up with a new tire. Carried a rear tire off the neighbors MF 135 around in the back of my pickup for a week with a sidewall split trying to find a tire shop that would fix or put a boot in it.
Everyone I talked to refused to even touch it, all said anything they did wouldn'd hold and no body had a used tire. This was in a 30 mile radius of Tulsa OK whear tractors are pretty common. Ended up buying a new tire from a large tire store.
Hurley J. D.
11-20-2005 10:34:37
If the tire is pretty good in all other respects, then you can have a good tire shop install a boot in it and get many more years of use out of it. I have had this done several times.
Any in Ct.
11-20-2005 15:37:14
 Re: Tire Problem in reply to Hurley J. D., 11-20-2005 10:34:37
Gemplers sells Tire boots. They have a web site. Used tires are hard to come by.
nw_bearcat
11-22-2005 05:23:14
 Re: Tire Problem in reply to Any in Ct., 11-20-2005 15:37:14
you could try .tiretown.com if you are w/in driving distance to KC, MO. They've got alot of used tires fairly cheap
