Front engine seal
Andy in Ct
11-20-2005 15:35:35
I had to replace the axle pin on my 640 and since it is all apart I thought I would replace the front seal. I don't want to by a whole gasket kit. The Ford part number is EAF 6700 - B. Has any crossed this to a different number? Is it something I could get at NAPA? Thanks.
Darin IN
11-20-2005 15:54:11
 Re: Front engine seal in reply to Andy in Ct, 11-20-2005 15:35:35
Andy, I just did the same to my 640. I'm trying to go thru my NH receipts and find the numbers for you. I bought the front main seal, governor shaft seal, and front engine cover gasket, each sold seperately. I also had to buy the oil pan gasket because I tore it while removing the front engine cover. I hope the following is correct and helps: CONN6700A front main seal($3.32), C5NN7277C Governor shaft seal($3.30), F2NN6020AA Front engine cover($1.86), 86602758 oil pan gasket($8.17)
Darin IN
11-20-2005 18:30:26
 Re: Front engine seal in reply to Darin IN, 11-20-2005 15:54:11
Correction on Governor shaft seal EAF18183B($6.27) Number supplied in above is transmission shifter boot, which also appears as a seal on my receipts.
