Order Ford 4000 Parts Online
Any trick or ideas rplacing clutch 4000HD Ind.
Anthony
07-16-2001 14:55:21
We have a '65 4000HD Industrial Backhoe, 4cyl diesel, no 3pt., no pto, I believe it is a single stage clutch. It appears that the clutch is gone. My brother found some clutch matrial, don't know exactly where he pulled it from, but he had a couple of pieces in his hand. The tractor can move on its own on level ground. We did a complete engine rebuild & new clutch, probably 12-15 yrs ago. Are their any tricks or neat ideas on doing this job.
I think the way we will takle it is, pull it under a tree, pick the front loader up, chain it to the tree with 4x4 under the arms for extra safety, then pull the engine & steering unit forward.
Ideas ???
Thanks
RickB.
07-16-2001 15:58:02
 Re: Any trick or ideas rplacing clutch 4000HD Ind. in reply to Anthony, 07-16-2001 14:55:21
If you can unbolt the front crossmember of the loader in front of the grille (or if it doesn't have one), you are on the right track.
