Order Ford 9N Parts Online
Oil for hydrolics on ford 9N
alancrego
12-04-2005 14:37:52
Can anyone tell me the correct hydrolic oil to use in a ford 9N?
soundguy
12-05-2005 05:14:10
 Re: Oil for hydrolics on ford 9N in reply to alancrego, 12-04-2005 14:37:52
I'd like to add, that your 9n has yellow metal ( lots of it ) in the hydro pump.. And technically.. gl-5 oils aren't safe for yellow metal ( unless they say so ). Castrol and penzoil do make a lube that is gl-4 and yellow metal safe. penzoil calls it gearplus.
Also.. TSC sells a gl1-gl3 type oil marked for ford trans.. that's also fine as well as wallmart 90wt gl-1 and napa 65-205 gl-1 oil.. or if you have no leaks.. or are in a cold environment.. any UTF fluid that meets the NH m2c134d spec will work fine ( wallmart.. tsc.. etc.. )
Soundguy
lumpy
12-04-2005 16:10:49
For most N's 80-90w is recomended. In cold weather sometimes it takes a while for the hyd. to start working. I start mine and let run at about 1/4 to 1/2 throttle for about 10-15 min. before using.
