Order Ford 8N Parts Online
5' or 6' foot rotatry cutter for 8n?
chris
07-18-2001 08:43:22
I am looking at purchasing a new rotary cutter, my question is weather a 8n ford is powerful enough to utilize a 6' foot cutter?
williy
07-19-2001 01:01:58
 Re: 5' or 6' foot rotatry cutter for 8n? in reply to chris, 07-18-2001 08:43:22
I have a 4ft for my 8-N and it does fine most of the time, however it will bog down when cutting tall grass (2-3 ft tall). Suggest the 4ft'er unless the grass you are cutting is short.
I would also recommend a slip clutch for your PTO shaft, this will prevent your tractor from being propelled forward by the momentum of the turning blade when you push in the clutch while mowing.
Williy
Clarence
07-18-2001 13:59:36
I was told that for every foot of cutter you have you should have 5HP. It also depends on what you are cutting.
tlak
07-18-2001 11:50:43
