No spark
Andy in Ct.
12-10-2005 18:01:14
I started my 640 today. Ran fine - shut it off. went to restart it and wouldn't start. No spark. Where should I begin?
old
12-10-2005 19:33:22
 Re: No spark in reply to Andy in Ct., 12-10-2005 18:01:14
Check if you get a spark at the points when you open them by hand with the key on. If you don't then you either have bad points or you have a bad switch or wire going to the coil. A few other things can also be wrong like bad rotor and or cap, or even the coil.
