Order Ford 600 Parts Online
FORD 4600 PTO
ANDREW 23
12-11-2005 18:56:42
THE PTO STOPED WORKING ON MY FORD 4600. WILL NOT SPIN ENGAGED OR NOT ENGAGED, THE 3 POINT LINKAGE IS STIHH WORKING BUT A BIT SLOW. I CHECKED THE HYDRAULIC FLUID WHICH IS LOW. WOULD THE PTO SYSTEM COME BACK ON LINE WHEN THE HYDRAULIC FLUID IS TOPED UP OF WILL IT NEED SURGURY AND IF SO CAN THE PTO BE SERVICED EASLY ?
Pernell
12-12-2005 09:00:48
 Re: FORD 4600 PTO in reply to ANDREW 23, 12-11-2005 18:56:42
Low oil level will interfere with it, hopefully that will take care of your problem. PTO on a 4600 is not an easy fix.
