Order Ford 3400 Parts Online
3400 three cyl gas
Beau Bouillion
12-15-2005 09:37:51
After sitting up for four or five years I got this tractor to start and run. Now I want to turn the battery around to a (-) ground like it is suppost to be. My plan is to replace the voltage regulator and remove and have tested the generator. Then with battery correctly installed polarize the generator. Don't laugh this tractor only runs with the battery backwards and the gen is not charging. Am I on the right tract here.
gerard
12-15-2005 10:50:04
 Re: 3400 three cyl gas in reply to Beau Bouillion, 12-15-2005 09:37:51
If engine will only run with battery polarity reversed, perhaps your coil is wrongly connected? Spark intensity drops when it"s the wrong way "round. If battery is +ve earth, then +ve coil terminal must go to earth.
Beau Bouillion
12-15-2005 11:35:37
 Re: 3400 three cyl gas in reply to gerard, 12-15-2005 10:50:04
Thanks for quick replies. I think the batterys polarity has not been reveresed because I tried it on another tractor and I tried installing the new coil every way you could wire it when I was trying to get a spark at the new points. I had installed the battery right then with a (-) grn. The starter worked and a volt meter shows 12 volts at the coil and points, But I got no spark untill I turned the battery around(+) grn like my father in law had done years ago, then I get a great spark and the tractor starts right up. I want to get it right before selling it so I'm back to trying to see if I can polarize the system back to a (-) grn.
soundguy
12-15-2005 12:04:03
 Re: 3400 three cyl gas in reply to Beau Bouillion, 12-15-2005 11:35:37
When you have the battery -grnd.. do check to make sure that the coil - is going to the points...
Soundguy
mhb@ufe
12-15-2005 09:49:28
I would check the battery with a volt meter first to make sure the polarity hasn't benn rversed in the battery itself.
