Order Ford 3000 Parts Online
Ford 3000 hydraulic lift
Bill Long
12-21-2005 20:27:20
My lift worked well during warm weather, but will not budge since it turned cold (30-45 degrees) The oil level seems to be OK but I have two or three diferent opinions how and where to check the oil level for the 3-point hitch. Any ideas?
hvw
12-22-2005 03:38:47
 Re: Ford 3000 hydraulic lift in reply to Bill Long, 12-21-2005 20:27:20
You may need to use a thinner oil like NH134 in cold weather. If you change the oil be sure to prime the pump.
lawman in sc
12-22-2005 12:53:22
 Re: Ford 3000 hydraulic lift in reply to hvw, 12-22-2005 03:38:47
I also have a 3000-diesel.I'm going to change the fluid.How do I prime the pump? Wasn't aware that I would have to do this.Thanks.
BobReeves
12-23-2005 10:09:21
 Re: Ford 3000 hydraulic lift in reply to lawman in sc, 12-22-2005 12:53:22
Guess I was lucky, just replaced all the hoses and rebuilt the two lift cylinders on my Loader. Tractor sat for almost a week without a drop of oil in the rear-end. Filled it up and after cycling the loader a few times everything works great. No symptoms of air in the system and this was without bleeding the pump.
hvw
12-22-2005 13:30:46
There is a plug, Usually a large allen bolt, at the rear of the pump. Loosen the plug but don't take it out. Pull the fuel shutoff out so the engine won't crank. Now spin the engine and at the same time loosen the plug until fluid runs out. Do that until you see no air bubbles then tighten the plug.
If you stop spinning the engine before you tighten the bolt air will be drawn back into the system. I used to just remove the plug and have a helper (my wife) spin the engine. It's easier to watch the flow. But it is a messy job.
I've read here that some people do this with the engine running and I tried that. But that pump is putting out so much pressure I couldn't get the bolt back in that way.
Afterwards your hydraulics should work fine. If they do for a while or a few days then get air back in the system you likely have a pump that needs attention.
BobReeves
12-22-2005 00:40:56
For the hydraulic - rear end oil, level plug is next to your right heel when sitting on the tractor.
