Need help with Casting #'s on 172 Diesel block
Barney---South
07-21-2001 05:56:22
I have bought a block for 'ole Scooter.It has just left the machine shop. Before I start assembling the engine, I would like to have Tony Jacobs or someone tell me what year I have. Ole Scooter is about a 1961 851 Diesel with a 5/16 hex drive oil pump. The engine I'm rebuilding has the same 5/16 hex rod that drives the oil pump. The casting #'s on the block on the starter side are:3F24. On the injector side is :CONN 6015J. I really appreciate all the information I have recieved here in the past. Thanks in advance; Barney----South Ga.
Tony Jacobs
07-22-2001 20:12:43
 Re: Need help with Casting #'s on 172 Diesel block in reply to Barney---South Ga., 07-21-2001 05:56:22
Hi Barney, Your block is dated June 24, 1963, and the casting number is correct for that year block. Post the model and serial number stamped on the transmission where the starter bolts in so we can check the year of the tractor also. Thanks Tony Jacobs
