Order Ford 9N Parts Online
Ford 9N Oil drain plug stuck
Ben Ballou
07-22-2001 22:51:55
Help!
Can't get the oil pan drain plug out of my recently purchased 9N. The nut is badly rounded, I've soaked it with penetrating oil and have tried to chisel but the cast metal just crumbles. I have a new replacement, so am unconcerned about trashing the old plug. I'm assuming heating with a torch down there would be risky, any help would be much appreciated.
Thanks,
Ben
MarkB
07-23-2001 03:44:33
 Re: Ford 9N Oil drain plug stuck in reply to Ben Ballou, 07-22-2001 22:51:55
Heat and a pipe wrench should do the trick.
This subject came up a while back, check out the thread below.
