Oil Pressure
Andy in Ct.
12-30-2005 16:39:05
My 640 runs with 80 + lbs. oil pressure. Checked it with two different guages. The manual says 40 - 45lbs. is normal. Is the pressure relief on the pump stuck. Is this something I should be concerned about?
John Nye
01-04-2006 20:06:54
 Re: Oil Pressure in reply to Andy in Ct., 12-30-2005 16:39:05
I have an 881 diesel that had 80 psi oil pressure all the time.Needed rings & bearings, while apart looked at oil pump. Relief valve acted like it could be sticky,no parts available so replaced oil pump.Put it all back together, fired it up. Now it has over 100 psi and blows oil out around the filter base. I suppose bearings are all tighter now so no leakage internally either. Yes I checked with another guage to be sure readings were accurate. Are weaker springs available?
Shakey
12-31-2005 14:07:05
My 640 was rebuilt years ago(not by me). It doesn't smoke or use 1 drop of oil. I carry 57-58 lbs. of oil pressure when it's under load. Idling hot it runs at about 30lbs or so. I would think that your engine running 60-65 lbs. when hot is excellent, but I'm no expert.
Andy in CT
12-31-2005 11:52:12
After it warms up and is at idle the pressure drops to 60 - 65.
russ1
12-31-2005 07:09:46
I have a 960 that has a rebuilt engine and runs about 65 psi consitently. I think that is good. Perhaps the manual is refering to minimum pressure levels?
Dave H (NY)
12-31-2005 05:28:14
Andy, there is an optional oil pump that is offered for the 134, 172 engines that puts out 80 to 100 psi, someone may have replaced your pump with a high pressure pump. When the engine gets hot and you are at idle where is the pressure reading?
Pernell
12-30-2005 17:39:45
You may want to change out the relief valve in the pump. All new pumps are industrial pumps.
john_bud
12-30-2005 18:59:25
 Re: Oil Pressure in reply to Pernell, 12-30-2005 17:39:45
Hey Pernell,
What would the down side be of running 80 lbs vs the 40-45 lbs pressure?
jb
Richard H.
12-31-2005 07:22:14
 Re: Oil Pressure in reply to john_bud, 12-30-2005 18:59:25
John my rebuilt 801 was holding pressure right at 58 psi hot or cold. I was led to believe that the neoprene rear seal was the way to go. After changing it and wedge seals it still leaked. Oh, did I mention twice? Thanks to Pernells advise, I just got through tearing it all the way down and put in rope seals. I have put at least 6 hours run time on it and have no leak. I know there are two relief holes in rear bearing cap and it makes me wonder if they can handle the higher volumn of oil. Just my 2cents, Richard
