Paint for 541 Ford.
BESinON
12-30-2005 21:58:49
Can someone help us with advice on the proper
paint to use on my brother-in-law's 541 Ford offset which he is restoring. He wants to get a
really nice paint job on it if possible to show
at local farm shows, plowing match, etc. It appears to have been a strange off red color
along with some gray. Are there numbers for automotive paints available or is the dealer paint
good enough for this job.
Thank you.
Bryan.
RICKWI
12-31-2005 11:06:51
 Re: Paint for 541 Ford. in reply to BESinON, 12-30-2005 21:58:49
You are correct. The red is the later orangeish red, rather than the dark red vermillion which was on the 8N. The dealer may give you the correct red, BUT most likely will try to give you the later white/grey rather than the correct green/grey which was used on the earlier tractors.
If it"s really a restoration get the paint from Just 8N"s or some other restoration supplier. If it just a fixup/repaint I"ve found the Tisco colors to be the shade I remember.
