Order Ford 4000 Parts Online
wiring for ford 4000 ignition
Angie Green
01-02-2006 07:56:40
my son took the wires off so I could purchase a new ignition and now it is a universal ignition and he don't remember how the wires go can anyone help me out thank you
Baba
01-05-2006 23:55:14
 Re: wiring for ford 4000 ignition in reply to Angie Green, 01-02-2006 07:56:40
facing ingn term of old switch two wide term at 6 oclock (battery con.)two narrow term.number2 at 10 oclock(lights ign gage cluster)one narrow term.number3 at 2 oclock (neutral safety switch and start solenoid.when key on batt. and #2 connect turn key to start sends power to #3 to start engine.the two main wires to trace out are battery(should be heavier) and wire to neutral safety switch.all others connect to #2. you will have to check new switch to see if it connects same as old in the on and start position.
tsix
01-03-2006 15:28:13
Lets try this one more time. Here is the CORRECT link, I hope.
tsix
01-03-2006 15:22:33
Try the post a few rows up about the 3000 wiring diagram. I believe they are exactly the same on a 4000. Here is the link.
Link
tsix
01-03-2006 15:25:01
 Re: wiring for ford 4000 ignition in reply to tsix, 01-03-2006 15:22:33
Sorry for the extra post, but I forgot to ask, do you know what year it is? Also, you may need to get a cheap meter from radio shack to get the locations correct. Good luck.
Rick
angie Green
01-03-2006 12:05:46
i need to know which wire goes on which screw on the new ignition switch..... ..i am not good at explaining things..... i am replacing just the ignition switch
tsix
01-02-2006 16:44:25
Try this link. Not sure if you are refering to the ignition switch or the the spark plug/ignition system. Hope it helps.
http://members.aol.com/naa60512/elect.htm
Catskill Pete
01-02-2006 09:47:54
We need a little more information for a 4000. Is it a 4 cylinder engine [early model] or a 3 cylinder engine [late model].
angie green
01-02-2006 11:23:05
 Re: wiring for ford 4000 ignition in reply to Catskill Pete, 01-02-2006 09:47:54
i am not sure i asked my son and he said it has 6 wires
Catskill Pete
01-02-2006 16:30:19
 Re: wiring for ford 4000 ignition in reply to angie green, 01-02-2006 11:23:05
It can't be a six cylinder if its a Ford 4000, so ask him how many sparkplugs it has. That should give us the info we need.
angie green
01-03-2006 12:39:21
 Re: wiring for ford 4000 ignition in reply to Catskill Pete, 01-02-2006 16:30:19
my son said it has 3 spark plugs
murn-ga
01-03-2006 13:28:17
 Re: wiring for ford 4000 ignition in reply to angie green, 01-03-2006 12:39:21
Angie, I'm a bit confused here. In one post you say it has 6 wires and I'm assuming going to the switch. In another you say it has 3 spark plugs. Is this not a diesel tractor? I don't recall a gas having 6 wires. If a diesel I can get you the color code tomorrow.
angie green
01-04-2006 05:56:42
 Re: wiring for ford 4000 ignition in reply to murn-ga, 01-03-2006 13:28:17
he told me he took off 6 wires from the back of the old ignition switch..... ....i had him look and there is only 3 spark plugs..... ..it uses unleaded gas ..... ...sorry for the confusion
murn-ga
01-05-2006 16:18:38
 Re: wiring for ford 4000 ignition in reply to angie green, 01-04-2006 05:56:42
Angie, sorry I missed your post yesterday but I guess It moved to second page. Even tho you have 6 wires you only have maybe 4 positions on the switch. You have got to figure out the hot wire and go from there. Will have a manual tues if you don't figure it out. Might post a new post.
angie green
01-03-2006 12:37:27
