Order Ford 3000 Parts Online
Ford 3000 clutch compatibility
Bob Unitt (UK)
01-05-2006 09:37:40
I have two Ford 3000's. I know from the serial no that one is a 1965 model, and I believe the other is a 1964 as it's marked 'Ford 3000 Super Dexta', (although it came with a 'D' [1966] registration plate attached, but no registration document).
I'm considering swapping the clutches between these two tractors. Externally the bell-housings look identical, and both have the same 8-speed live-pto gearbox and two-position clutch. Before I start tearing things apart, I'd appreciate your opinion as to :-
Are these two tractors are likely to have the same model of clutch ? ...or... Did anything significant happen to Ford 3000 clutches in the mid-60's which might make them non-interchangeable ?
Pernell
01-05-2006 12:33:07
 Re: Ford 3000 clutch compatibility in reply to Bob Unitt (UK), 01-05-2006 09:37:40
If both are equipped with the same PTO drive, it shoudn't be a problem.
