Order Ford 2000 Parts Online
hydrolic problems on Ford 2000
big tony
01-06-2006 13:00:33
I have a 1971 ford 2000. The lift works spiradicly, sometimes it will not move, but when it takes off it seems to work fine. Then I may lower the lift and it won't work again. Seems to be getting worse. Works better after I run the pto for 20 min. Would it help to drain and put new fluid in the tractor. Or is there something to simple to check before I start tearing it down. Help, got cows to feed.
