Model NO. Help
Bob in WI
01-11-2006 16:47:34
Hi to All,
I have a Ford 2000 stamped Model 21205, S/N <>3610<>. I understand the model to be 134 cu. in., produced in 1963 or later, adj. front end, SOS trans. w/540rpm independent pto but need help understanding what the s/n is telling me. Thanks in advance to any and all that can help!
Jim.UT
01-11-2006 19:05:02
 Re: Model NO. Help in reply to Bob in WI, 01-11-2006 16:47:34
The diamonds tell you it came with cast iron cylinder sleeves in the engine. The number is a sequential serial number and will tell you the month and year it was built if you have the right reference books. I have the right book, but it's at work. I'll be happy to look it up for you tomorrow, but you'll have to email me a reminder in the morning or I'll forget.
If you click on the serial number link to the left (under the "Research & Info" heading) you'll be able to find the year of manufacture. The book I have also gives the month. If you don't need that level of detail, then the link on this site will be good enough.
Bob in WI
01-12-2006 09:26:22
 Re: Model NO. Help in reply to Jim.UT, 01-11-2006 19:05:02
Jim.UT,
Thanks for the reply, just a reminder to check on my s/n.
Jim.UT
01-12-2006 10:27:11
 Re: Model NO. Help in reply to Bob in WI, 01-12-2006 09:26:22
Bob, the very first serial number was 1001 so yours is the 2,610th built. Production started in August 1962 and 2,425 units were built that month. So the first serial number in September 1962 was 2426. The first serial number in October 1962 was 4810. That makes yours the 1,185th tractor built in September 1962 out of 2,384.
If you look at a calendar for that month and make some assumptions you find that your tractor probably was built on Sept 17, 1962....a Monday. The assumptions are:
Even production during the month
Plant closed on weekends
Plant closed on Labor Day.
How's that for too much information?
Bob in WI
01-12-2006 15:02:34
 Re: Model NO. Help in reply to Jim.UT, 01-12-2006 10:27:11
Jim.UT,
Many thanks!
