Order Ford 4000 Parts Online
4000 4 cyl diesel air cleaner oil bath to dry type
bjr
01-16-2006 07:16:16
Would it be possible to convert from oil bath to a paper element type air cleaner on a older 4000 4 cylinder diesel? Also has anyone seen a replacement proof meter for sale for a SOS trans?
bjr
octave
01-16-2006 18:45:25
 Re: 4000 4 cyl diesel air cleaner oil bath to dry in reply to bjr, 01-16-2006 07:16:16
Yes It can be done with the right parts as far as I know the 4000 only came with a oil bath air cleaner
You would need the nose cone off a 4600 because the hood dog leg on the right has a hole for the dry cleaner the 4000 oil bath cleaner is serviced by removing the grill to get to the oil cup
Larry NCKS
01-17-2006 04:14:38
 Re: 4000 4 cyl diesel air cleaner oil bath to dry in reply to octave, 01-16-2006 18:45:25
I think you're on the wrong tractor! This is a 4 cylinder prior version as per the title of the post.
ErnieDD
01-16-2006 17:10:16
Stay with the oil bath, particularly in dusty conditions.
bfloyd
01-16-2006 12:26:11
Yes its possible, but why would you want to? Those paper filter can be expensive and clog up in a hurry in dusty conditions. Paper filters also have more of a presure drop accross them than an oil bath which may require enlarging the piping for the air intake system in order to provide enough air for the engine to breath under load conditions.
Hurley J. D.
01-16-2006 10:00:16
I bought one from Walts tractor supply.
