Year Mfg
Andy Walter
01-18-2006 06:10:32
I purchased a Ford 3000 and am unsure of the model year. Is there a place on this tractor where this can be determined? I would like to purchase the manuals for this machine
Jim.UT
01-18-2006 13:19:51
 Re: Year Mfg in reply to Andy Walter, 01-18-2006 06:10:32
Try the link. It should help.
Fordfarmer
01-18-2006 07:11:43
I don't have a book handy that will give you the exact year, but for the purpose of buying a manual, you just need to know if it's an early ('65 to 7-19-'68) or late (7-20-'68 to '75) model. The serial and model numbers are stamped on the implement mounting pad at the right front corner of the transmission, just behind the starter. The engine serial number is stamped near the bottom of the block, just above the oil pan (could be either left or right side), and can be used to determine early or late model also. Your serial number should end with an 'N' if you have an early 3000, or a 'C' for a late model. The engine serial number should start with the N or C. If you find the numbers and post them here, I'm sure someone will decode them for you. Hope this helps.
