Order Ford 3000 Parts Online
Ford 3000 Hydraulic Problem
AndyTX
01-25-2006 20:41:02
Just bought a 3000 diesel, got it home and tried to lift a 1000 lb roll it did not move. Instead fluid started spraying from the hydraulic pressure line where is goes into the rear end. The steel line pulled out about one quarter inch. Is this a flared steel line? Should a bypass valve have opened to divert the pressure so this would not have happened? The nut where the line attaches is tight. Any thoughts and advice would be greatly appreciated.
RickB
01-26-2006 03:20:14
 Re: Ford 3000 Hydraulic Problem in reply to AndyTX, 01-25-2006 20:41:02
The nut has a seal within it. The nut/seal assembly will need to be replaced. If the tube is scored badly about 1/2" from the end, replace it as well. Parts available at your New Holland dealer. Take the unit code of the tractor with you.
