Order Ford 4000 Parts Online
'62 4 cyl diesel 4000 SOS Engine Fan Blade
bjr
01-26-2006 18:27:55
I only have two blades on the engine fan is this a original or has it been debladed somehow? I have no fan shroud either, should I have one? I live kinda in the desert E WA. state so in the summer we see some 100 deg. days. bjr
Farmer Alf
01-27-2006 08:40:03
 Re: '62 4 cyl diesel 4000 SOS Engine Fan Blade in reply to bjr, 01-26-2006 18:27:55
Hi BJR,
While working yer tractor look at the temperature gauge. If it doesn't work spend $20 and buy one. If it says yer engine is fine dont worry about how bald yer fan is. If yer hot get a more blady fan or a shroud or clean yer rad. This will work even if it is a 1935 4000. :)
John in OH
01-27-2006 02:12:00
The reason for the two bladed fan is for the diesel engine to runner hotter than a gasoline engine. They also use a higher degree thermostat. Running hotter helps atomize the fuel for better combustion in the direct fuel injection engine.
B. Jones
01-26-2006 20:04:51
We have been running a 971-d for many years with the 2 bladed fan. Even on hot days we never really had any heating problems if we kept the radiator clean. I think most tractors will heat if you let the radiator get all plugged up. Yes ours does have the shroud on it. I remember years ago I used to see a red glow out the exhaust pipe on a dark night in a hard pull. It still didn't heat though. By the way we always had a 4pound pressure cap.
Kelly Jewell (KY)
01-26-2006 18:59:32
bjr, two blades is correct for your 172" diesel, however, if its a 4000 its a 1963 or 1964 not 1962 and yes it did have a shroud and should have one....Kelly.
Larry NCKS
01-26-2006 19:21:31
 Re: '62 4 cyl diesel 4000 SOS Engine Fan Blade in reply to Kelly Jewell (KY), 01-26-2006 18:59:32
I have a '62 4000. Don't know when they started building them. Mine was built in late November of '62.
Bjr, you should have a shroud, but as at least one other has said, the 172 diesel engine had only a 2 bladed fan.
john in la
01-27-2006 03:28:54
 Re: '62 4 cyl diesel 4000 SOS Engine Fan Blade in reply to Larry NCKS, 01-26-2006 19:21:31
The 4000 industrial started production in late 1960 (I think November)
And the 4000 ag started production in mid 1962 (I think it was June or July)
Larry NCKS
01-27-2006 06:06:58
 Re: '62 4 cyl diesel 4000 SOS Engine Fan Blade in reply to john in la, 01-27-2006 03:28:54
Yep, I believe that's correct. Thanks for putting that time frame to it, John.
Kelly Jewell (KY)
01-27-2006 07:02:03
 Re: '62 4 cyl diesel 4000 SOS Engine Fan Blade in reply to Larry NCKS, 01-27-2006 06:06:58
So, what your saying if its built in 1962 then its a 1962 Model? Like a 1947 8N? I don't think so.
Dean
01-26-2006 18:45:50
The original Ag fan had 3 blades. Industrial versions had 6 blades. Both had shrouds.
You will probably need both a good fan and shroud to keep the engine cool when working it at high ambient temperatures.
Dean
john_bud
01-26-2006 19:14:27
 Re: '62 4 cyl diesel 4000 SOS Engine Fan Blade in reply to Dean, 01-26-2006 18:45:50
Dean,
The diesel engines had 2 bald fans, even the industrial and the HD industrials too.
jb
Larry NCKS
01-27-2006 06:09:31
 Sorry, but I can't resist . . . in reply to john_bud, 01-26-2006 19:14:27
What's a bald fan look like? :) Yep, I make typos too. LOL
john_bud
01-27-2006 07:58:42
 Re: Sorry, but I can't resist . . . in reply to Larry NCKS, 01-27-2006 06:09:31
Larry,
Ha, you caught me!
But seriously, none of the fans on my tractors have any hair...
I am still chuckling... Bald fan!
jb
Dean
01-26-2006 20:45:04
 Re: '62 4 cyl diesel 4000 SOS Engine Fan Blade in reply to john_bud, 01-26-2006 19:14:27
OOps. Should have read the entire Subject. I missed the operative word "diesel."
Dean
