FORD 541 HIGH CROP OFFSET
BUDJEN.NJ
01-30-2006 03:11:30
I'M LOOKING AT A HIGH CROP OFFSET 541 IN VERY NICE CONDITION WITH FRONT CULTIVATORS. I THINK IT'S A 1959 BUT CAN'T FIND ANY SERIAL NUMBER. WHERE SHOULD I LOOK? WOULD 4500 BE A GOOD PRICE? THANKS FOR ANY HELP AND ADVISE. BUDJEN.NJ
Leon Bell
02-13-2006 02:46:19
 Re: FORD 541 HIGH CROP OFFSET in reply to BUDJEN.NJ, 01-30-2006 03:11:30
Awhtx is right on serial# location and it is true that the paint will hide the numbers.
I have a 541 Offset with cultivators. I will have to sell it since I am moving off the farm after 50 years. Have used this tractor every year and kept it in good condition. Excellent for restoration. Few were made, it has got to be a classic. Interested? E-mail or phone 1-859-234-
3748.
9n1411
01-30-2006 19:22:56
If it is a true high crop it will be 541-4, with 38 in rear tires very rare. Might just be a regular 541 with 28 in tires. Check my 541 at: www.burthudson.com/tractors
BUDJEN.NJ
01-31-2006 03:31:34
 Re: FORD 541 HIGH CROP OFFSET in reply to 9n1411, 01-30-2006 19:22:56
THANKS FOR THE IMFO. GUESS THE 541-4 IS PART OF THE SERIAL NUMBER. I HAVE TO REMOVE THE STARTER TO SEE IT? COULDN"T GET YOUR WWW. TO OPEN. BUD
Jim.UT
01-31-2006 11:40:11
 Re: FORD 541 HIGH CROP OFFSET in reply to BUDJEN.NJ, 01-31-2006 03:31:34
The numbers are on a flat horizontal surface. If you stand to the left side of the tractor and look at the starter, then shift your gaze to the rear of the tractor about a foot, you'll see the flat spot I'm talking about. It's kind of below the starter solenoid and air cleaner. Below the flat spot are two empty bolt holes.
Here's the link to Burt's tractors.
9n1411
01-31-2006 08:14:16
www.burthudson.com/tractors SHOULD work . DID anyone else have trouble?
awhtx
01-31-2006 06:36:36
541-4 is the model number and is stamped just above the serial number. You do not have to remove the starter to see the numbers. They are stamped into a flat spot on the transmission housing just aft (towards the rear of the tractor) from the starter. If the tractor has been repainted the paint may have filled in the numerals and you will need to remove it.
Feron
01-30-2006 03:54:00
The serial # is just behind the starter on the flat spot on the bellhousing. $4500. doesn't sound to bad, depending the condition
BUDJEN.NJ
02-03-2006 14:56:01
 Re: FORD 541 HIGH CROP OFFSET in reply to Feron, 01-30-2006 03:54:00
THANKS FOR ALL THE INFORMATION. IT IS A 541-4 AND I HOPE TO PICK IT UP TOMORROW. NOT SURE HOW LONG I'LL BE ABLE TO HANG ONTO IT. BUD
9n1411
02-04-2006 16:59:14
 Re: FORD 541 HIGH CROP OFFSET in reply to BUDJEN.NJ, 02-03-2006 14:56:01
Keep my name on file as a prosective buyer. thank you.
