serial nos.
ford-s
01-31-2006 08:15:59
sirs,i have what was told to me is 701,i can't find a number.i looked around the starter,flat place behind starter,both sides of motor.the only nos.found were;03NN-7006 B,and 310608.It looks very much like a powermaster,it was painted blue,and white.Diesel engine with the 'S-O-S tranny.Any help would be appreciated.CW
awhtx
01-31-2006 18:43:10
 Are you sure it's not a 971? in reply to ford-s, 01-31-2006 08:15:59
That number you posted- 310608 - are you sure it's not 310609? The 172 diesel engine has 310609 cast into the right side of the block. I don't know what number the 144 diesel block has.
ford-s
02-01-2006 06:56:50
 Re: Are you sure it's not a 971? in reply to awhtx, 01-31-2006 18:43:10
awhtx,at closer inspection it is a 971,thanks.Is the engine the only thing that varies between a971 and a 771? cw
awhtx
02-01-2006 07:43:09
 Re: Are you sure it's not a 971? in reply to ford-s, 02-01-2006 06:56:50
The rear axle on an 800/801 is larger than the rear axle on a 600/601. I would assume the same applies to the 700/701 and 900/901 but I'm not sure. Maybe one of the experts will help you on that.
The engines (134G,144D,172G,172D) all have the same bolt pattern where the engine bolts to the transmission so it is also possible that you have a 771 with the larger 172D engine.
Jim.UT
01-31-2006 11:33:18
 Re: serial nos. in reply to ford-s, 01-31-2006 08:15:59
Tractors from that era with diesel engines often have their serial numbers erased by years of leaking battery acid. Notice the battery is located directly above the area where the numbers should be. A 701 with SOS could only be 771 or 781 the difference being a 771 would have a single speed pto and the 781 would have a dual speed pto.
souNdguy
01-31-2006 10:05:03
Here's some info.. hope it helps.
Soundguy
7** High clearance row-crop w/134 cu. in. gasoline/LP-gas or diesel engine
**1 Series designation, 1958 to 1962
***-D Diesel engine *1* Select-O-Speed transmission w/o PTO
*7* Select-O-Speed transmission w/single speed PTO *8* Select-O-Speed transmission w/two-speed and ground drive PTO
ford-s
01-31-2006 14:38:32
 Re: serial nos. in reply to souNdguy, 01-31-2006 10:05:03
thanks guys,then my tractor is a 771.
