Order Ford 2000 Parts Online
where are the #'s found on a ford 2000 and what do
adam mcb.
01-31-2006 09:16:32
i just got aford 2000 and i"m not sure where to find the serial nnumbers and what they mean
souNdguy
01-31-2006 09:50:08
 Re: where are the #'s found on a ford 2000 and wha in reply to adam mcb., 01-31-2006 09:16:32
Check the bellhousing above the starter.. post them back here. Should be able to determine build date, and sn, and model options from the codes. I don't have my info sheet here with me at work.. but when yo post the codes and # someone here will have the info to tell you when it was made / options.. etc.
Soundguy
adammcb.
02-01-2006 17:23:12
 Re: where are the #'s found on a ford 2000 and wha in reply to souNdguy, 01-31-2006 09:50:08
here are the #'s 21201 adn 66053
murn-ga
02-02-2006 14:50:38
 Re: where are the #'s found on a ford 2000 and wha in reply to adammcb., 02-01-2006 17:23:12
Those look correct. Probably a 2000 1964 4 cyl.
souNdguy
02-01-2006 17:36:15
Hmm.. those numbers don't seem to jive with the code chart I have.. should be some letters there too..on the model id.. 2 is 2000 ( or B is after 68 )
10 is ag all purpose, 20 is row crop.. etc..
1=diesel, 2=gas
1-6 are pto options
a-k are tranny options.
for instance, my 5000 is a E1014C
Soundguy
adammcb.
02-09-2006 15:49:54
 Re: where are the #'s found on a ford 2000 and wha in reply to souNdguy, 02-01-2006 17:36:15
SOMETING DON'T ADD UP IT'S A GAS
adammcb.
02-09-2006 15:46:15
i found the 3'S ON THE LEFT SIDE OF THE BELL HOUSING
adammcb.
02-01-2006 17:23:11
