Carborator
Andy in Ct
02-10-2006 15:13:06
Will a float that is set incorrectly cause a tractor to run rough, backfire, etc?
Jerry/MT
02-10-2006 19:36:51
 Re: Carborator in reply to Andy in Ct, 02-10-2006 15:13:06
Old is right, but a poor ignition system can cause the same kind of problems. Before you pull the carb off, make sure you have a fat, bluish spark.
Pull a plug wire of the spark plug, put a paper clip in the boot makingsure it contacts the metal connector, hold it about an eighth of an inch away from a good ground, turn on the key and try to start. It should through a fat, bluish spark, not orange or yellow, but fat and bluish.
Jerry/MT
02-10-2006 19:35:56
old
02-10-2006 17:10:20
Simple answer yes. Backfire can be caused by a carb running to lean or rich. If the float closes to fast it will run lean and if it doesn't close fast enough it will run rich. Also the way a main jet is set will also cause those problem.
