RING GAP 172 cu. in.
8-N Nut
02-20-2006 20:00:39
Doing some work on a Ford 800! Does anyone know the piston ring gap on standard pistons? Four cylinder gas. 172 c. i. TIA Ron.
Bob
02-20-2006 20:52:49
 Re: RING GAP 172 cu. in. in reply to 8-N Nut, 02-20-2006 20:00:39
Piston ring end gap, or space between ring land, and ring?
I don't have specific specs for your engine at hand, but here are some typical generic "specs."...
Typically, with new rings in new pistons, side gap will be as low as .0015", with a wear limit up lcose to .005".
Piston ring end gap will run about .003" per inch of bore for new rings in a new bore.
