1959 Ford 871 select-o-speed
D Deeder
02-28-2006 13:59:19
I am in the process of restoring a 1959 871 Select-o-speed. It is currently red and gray. Looking at it, it appears that the front/back axles, block, steering shaft, oil filter cover, etc were painted gold at one time. Can anyone assist me in finding out what the original color of this tractor was? Was it a demonstrator? Serial nr: 66228. Thank you in advance.
Feron
02-28-2006 19:44:15
 Re: 1959 Ford 871 select-o-speed in reply to D Deeder, 02-28-2006 13:59:19
third party image
I just restored this 1959 881 gold serial # 69769, I used NAPA sand met #13167. The Dupont # is 44453G.
DaveH IA
02-28-2006 19:22:51
third party image
I used Martin Senour 99L 13167 acrilic enamal on mine ser 65217 971 gas
Jim.UT
02-28-2006 18:00:35
I'm no expert, but from what I've read your serial number is in the correct range to be a gold demonstrator. If I were restoring it, I would carefully remove the top coats of paint and try to leave the original gold undamaged. Nice find!
ZANE
02-28-2006 17:14:58
The gold tractors were dealer promotional demonstrators.
