Is 6v always + ground?
Bob Lee
03-09-2006 08:33:27
I'm working on a ford 601 powermaster for a friend of mine. The battery is installed with the + lead on the starter, and the - lead disconnected. It has a 6v battery that has been charged with a 12v charger. Reckon this is why he can't keep a battery in it?
guest
03-09-2006 14:19:35
 Re: Is 6v always + ground? in reply to Bob Lee, 03-09-2006 08:33:27
If all he did was over charge the battery
I don't see any damage to the coil, resistor,
points, or starter. With the switch off the charger should not go anywhere else. If he
turned on the key the 12 volts would go through the
coil, but depending on the capacity of the charger
it may be no damage done.
Larry NCKS
03-09-2006 09:51:11
6v is positive ground in all Ford tractors prior to '65 anyway. Your friend is wired backwards and overcharged! :-)
BobLee
03-09-2006 10:47:20
 Re: Is 6v always + ground? in reply to Larry NCKS, 03-09-2006 09:51:11
10-4. That's what I thought. Other than the battery, what else do you reckon is messed up?
gerard
03-09-2006 15:41:38
 Re: Is 6v always + ground? in reply to BobLee, 03-09-2006 10:47:20
battery may be OK - test it. Maybe low on water, but unless it got hot, it shouldn"t be damaged.
