Order Ford 2000 Parts Online
2000 Hydraulic Lift Problem
Charlie Armenta
08-11-2001 21:04:18
I OWN A 1972 FORD 2000 3 CYL. DIESEL. THE HYDRAULIC LIFT SYS. ONLY RISES +-6" WHEN LIFT CONTROL LEVER IS POSITIONED ALL THE WAY TO THE REAR AND THE SELECTOR LEVER IN THE UP RIGHT POSITION. WHEN POSITIONING THE SELECTOR LEVER ALL THE WAY DOWN AND HOLDING IT AT THIS POSITION IT WILL RAISE IMPLEMENT. BUT IF LET GO IT FALLS FAST NO MATTER WHAT POSITION THE LIFT CONTROL LEVER IS IN. PLEASE HELP.
Richard C. Rose
08-21-2001 16:11:50
 Re: 2000 Hydraulic Lift Problem in reply to Charlie Armenta, 08-11-2001 21:04:18
The problem you have is internal on the position control linkages. There is a hardened 5/16" pin which run on a quadrant cam to register the lift arms current position for the position control.
This pin wears and creates the symtoms you speak of. It can be replaced or even knocked out, turned & refit. I sometimes use the shank end of an old 5/16" drill. But you do need to lift the hydraulic chest to do this.
As far as the spool & linkage settings go after you have replaced that pin you generally find they are not that far out but spec's are available for those setting.From me if you wish.
Regards
Dicko
