Order Ford 6000 Parts Online
Ford 6000 injector timing.
63ford6000
03-27-2006 17:21:01
I have a 63 Ford 6000. I bought it with a M&W turbo. It has a pretty nasty miss with no load, and the turbo flange was broke. Also the seals leaked on the turbo. I bought a new garret replacement turbo for it and new injectors. The miss is still there. The miss goes away under power. Doesn't miss a beat. I checked the injector timing and it is way off by the manual. The manual says 26 degrees btdc. My tractor is about 14 degrees btdc. Anybody know the proper timing for a turbo charged 6000? Or any other in sight about my problem? I don't believe I have a bad cylinder because it runs great under full load. It pulls a 3 bottom 16" plow in heavy clay in 7th gear and doesn't even miss once.
gerard
03-28-2006 13:24:51
 Re: Ford 6000 injector timing. in reply to 63ford6000, 03-27-2006 17:21:01
either a valve or injector pump issue. Miss will clear with revs.
63ford6000
03-28-2006 14:52:34
 Re: Ford 6000 injector timing. in reply to gerard, 03-28-2006 13:24:51
I think I found my problem. The injector pump drive coupling is loose. The woodruff key is wore, so it is allowing the coupling to move changing my injection timing almost 14 degrees. I belive it has retarded the timing so far that it is ijecting to close to TDC. I will let you know how I make out. Thanks, John.
