Ford Tractor PTO
Andy Walter
03-30-2006 07:30:04
I have a ford 3000 tractor... about a 1975 model I think. Without a load on the pto, it seems to engage and disengage fine. Once I attached a cutter to it though it will not engage with out significant grinding. I am assuming that it has some kind of slip clutch. Is this a common problem with older tractors and is it expensive to repair.
souNdguy
03-30-2006 07:53:29
 Re: Ford Tractor PTO in reply to Andy Walter, 03-30-2006 07:30:04
Is your model the 8spd/live pto ( 2 - stage clutch)
Are you pressing the clutch down before engaging the pto? Is the clutch adjsuted correctly?
Soundguy
Andy Walter
03-31-2006 08:06:32
 Re: Ford Tractor PTO in reply to souNdguy, 03-30-2006 07:53:29
Definantly pressing the clutch down....as to whether or not it is adjusted properly, I can't say. How do you know? I have noticed that the tractor moves just slightly when you shift from neutral into a gear but of course that is on th transmission side.
souNdguy
03-31-2006 20:50:37
 Re: Ford Tractor PTO in reply to Andy Walter, 03-31-2006 08:06:32
I'd say the clutch is not fully disengaging.. may be an oily clutch issue.. adjustment, or wear on components. Thats why you are having pto grinding...countershaft is spinning and pto shaft is stopped... this creates problems and grinding at the coupler..
Soundguy
