Order Ford NAA Parts Online
NAA ?
behrjack
03-31-2006 13:05:21
Just bought anouther tractor the # back of starter is NAA80912 with a little triangle wondering the year model? The engine runs great good oil pressure no smoke 3 speed tranny seems to shift fine does have a little thunk sound in the back wheel some place. Paid 1550 guy said it was a jubilee its not any comments on the price? Thanks
old
03-31-2006 13:53:36
 Re: NAA ? in reply to behrjack, 03-31-2006 13:05:21
3 speed tranny????? ???? The numbers say its a NAA or jubilee but both of them had 4 spped trannys. Is the engine a flat head or a valve in head engine?? The tranny says its a 9N or 2N but the numbers say its the other. I think you need to look closer at it and or post a picture.
behrjack
03-31-2006 14:18:15
 Re: NAA ? in reply to old, 03-31-2006 13:53:36
Found the 4 th its straight up just saw the 2 + 3 at first alot of thick white bird do do had it covered up. Also see a sort of a wood plug on the clutch side up high on side of tranny like maybe a 2 speed shifter would be?
old
03-31-2006 14:52:53
 Re: NAA ? in reply to behrjack, 03-31-2006 14:18:15
It may have at one time had a sherman tranny in it but who knows. I have seen them removed because of haveing problems with one and I have also seen the shifter removed and still have the sherman in it. Look on the left of this page under research&info and look up your numbers and you will be able to figure out what it is. Both the Jubilee and NAA serail numbers start with NAA. The reason is because the Jubilee is a NAA in many ways other then the hood emblem and the year it was made which would be 1953 and the NAA was made in 1954
