Order Ford 960 Parts Online
Pic of 960 front weight box?
Brad_bb
04-05-2006 11:31:31
Does anyone have a pic they could post or send me that shows what a front end weight box and weights looks like for a 1955 960 Ford Row crop tractor?
Thanks.
Brad_bb
04-06-2006 06:36:26
 Re: Pic of 960 front weight box? in reply to Brad_bb, 04-05-2006 11:31:31
third party image
Sorry for the confusion, I have a narrow front end. See my pics on the pic site. Thank you for the pics guys!
Rob Mo.
04-05-2006 19:57:29
Do they even make an aftermarket wieght box? I'm stomped on what kind of weights you put in. Will the pie weights work or are there special weights?
RICKWI
04-05-2006 19:20:43
third party image
This is one built to hold Mountain Dew for the tractor shows. but I don't have a tractor to put it on and quit the Dew.
Kelly Jewell (KY)
04-05-2006 14:21:11
Brad, started to say your not supposed to use these with a wide front, but you have a 1955. The weight box weights 130 lb. and holds six 48-lb segments for single front wheel and narrow front only. Wide front uses weights inside front wheel.
Jim.UT
04-05-2006 14:24:46
 Re: Pic of 960 front weight box? in reply to Kelly Jewell (KY), 04-05-2006 14:21:11
Kelly, I always thought that, too. But if you look at the last pic I posted it shows a wide front 900 with a weight box. Is that because it's a '55 with an aftermarket WF?
Kelly Jewell (KY)
04-06-2006 18:51:35
 Re: Pic of 960 front weight box? in reply to Jim.UT, 04-05-2006 14:24:46
Jim, I saw that pic too. I don't think you can do much with the 1955 or early 56 as they have the one piece front end. I have a 1964 4000 High Crop with the wide front. It bolts up like all the normal wide fronts and it uses the bottom two holes, don't see any room for a weight box. And thats what the owners manual says. I don't have a clue on the aftermarket wide front, could have room.....Kelly.
Jim.UT
04-05-2006 13:57:55
third party image
Here's a pic I found in the tractor photo gallery of a 901 with a weight box. It's not a closeup of the box itself, but it gives you an idea.
Jim.UT
04-05-2006 13:59:37
 Here's another one. in reply to Jim.UT, 04-05-2006 13:57:55
third party image
Dirtier, but a closer view.
Jim.UT
04-05-2006 14:04:10
 And one more... in reply to Jim.UT, 04-05-2006 13:59:37
third party image
Here's one on a 900 rather than a 901.
