oil pump pressure tube fit so pan will go on?
bjr
04-10-2006 06:35:31
I have 4000 w/172D that I'm rebuilding and got the oil pump installed and am really struggling to get the pressure tube to go in to the block side far enough for the oil pan to lay flat against the block. There is a releif channel stamped in the pan for the tube. Anyway the question is. Is there a update in the pressure tube with shorter radius bends that allow for closer to engine fits to get the oil pan back on? The I&T manual doesn't address any issues with the tubes, just says install them. bjr
bjr
04-10-2006 08:35:57
 Tube is tight fit in pump plate in reply to bjr, 04-10-2006 06:35:31
Tube was tight fit in oil pump plate. I had to make a gasket for it. To get the tube in I loosen the oil pump plate inserted tube then tightened all back down as evenly as I could. I think pan could have been bumped and dented by previous owner. I see one repair weld in pan about two inches long. Has anyone ever had to maybe make a new tube out of some of the maleable (soft steel hydraulic tube) tubing or can a new still be ordered from Ford dealer or aftermarket somewhere? I'll try and body and fender the pan a smidge to expand for the tube, I need like a half inch to get pan to mate to the block. Thanks for the pictures, I see I need to put the support clip on suction tube back on, I think it's still in the parts washer or parts bucket. bjr
john_bud
04-10-2006 13:03:15
 Re: Tube is tight fit in pump plate in reply to bjr, 04-10-2006 08:35:57
I think the tubes are still available from FNH. Did they come off ok, or was it bought apart?
jb
bjr
04-11-2006 10:24:21
 Oil Pan is On in reply to john_bud, 04-10-2006 13:03:15
Thanks for the pictures and help. I did some body and fender work on the pan. The recessed trough was dented in where the tube lays when the pan is on. Also I didn't have the tube slip coupling end inserted quite enough. So through a combination of things I was able to get the pan on. It's still a close fit. Now, I'm trying to come up with a engine mount stand fixture to be able to run the engine on the floor before assemblying to tractor. I would rather fix things before being attach to the rest of the tractor. Well thanks again bjr
john_bud
04-10-2006 06:47:26
 Re: oil pump pressure tube fit so pan will go on? in reply to bjr, 04-10-2006 06:35:31
Did you also change the pump? Bend the hard lines?
Here are some pictures of my 172D bottom end for comparison.
third party image
HTH
jb
