Order Ford NAA Parts Online
Jubilee hydraulic line
Bill Oakes
04-16-2006 07:33:38
I have damaged the hydraulic line that runs from the engine mounted pump back to the rear of my Jubilee. Can I buy this part from Ford or possibly another source? It is two separate pipes instead of a cast manifold.
robil
04-17-2006 04:20:42
 Re: Jubilee hydraulic line - for sale in reply to Bill Oakes, 04-16-2006 07:33:38
I have a set of lines (pressure and return) that I could sell you. Let me know if you need them. mlibor@morganlewis.com
Ultradog MN
04-16-2006 14:31:39
 Re: Jubilee hydraulic line in reply to Bill Oakes, 04-16-2006 07:33:38
Bill,
I looked under the hydraulic section here on this site and didn"t see the hyd manifold.
I would run an had in the classifieds here.
It is an item that doesn"t sell real fast so I"d think you can find a used one.
If you don"t find one then as Dave said you can repair your lines with hyd hose.
I changed out the rear end on my 3000 to a 3600 this spring. The hyd lines are different so I used hoses to make my connections. Went to the hyd shop and they sold me compression fittings that worked on the pressure side and a chunk of suction hose to refit the suction line.
It"s working good so far - no leaks, good lift.
PS if you just put a hole in one or both of them they could be brazed real easy.
Jerry
jimNCal
04-16-2006 10:43:25
Ditto checking here first. Check with Brian Unger. He's easy to find and is a great resource for all things Ford.
Dave in Ms
04-16-2006 10:11:54
I don't know if it is available from this site, but I would check here first. Failing that, try ebay. Somebody is bound to have one thay will part with. If all else fails, you can go this route: I fixed one for a friend a few years ago by replacing the pipes with hydraulic hoses and the mounting flanges with adapters made from Aluminum bar stock. However, I'm a retired tool maker and still have access to a machine shop. If you had to hire it done, it would be pricey.
