3-point hitch arm stripped spline
Gary
08-16-2001 03:56:24
1967 4000 3-point hitch lift arm stripped at the spline - one arm up & one arm down. What's the best way to fix? Weld it, drill a hole between shaft & sleeve & screw in a bolt for a "key", try to find a used arm (shaft teeth would still be worn), some way to use JB Weld to build back up, other ideas, buy new arms & shaft (got to cost a bundle) ????? ?
Thanks
Gary
tlak
08-16-2001 08:23:42
 Re: 3-point hitch arm stripped spline in reply to Gary, 08-16-2001 03:56:24
I personally would get a new or good used matched set arm & shaft. Then its fixed for another 50-100 years. Somebodys always parting out a tractor.
