Order Ford 600 Parts Online
Ford county 7600 Four hydraulic problems
Alan Bosley
04-20-2006 11:52:56
Advice needed. Just bought a tidy 7600. Dual Power. 3 pt linkage worked when I tried it but now does not work. Pushed in the selector valve knob. Nothing happens on lift for say 4 - 5 mins then the linkage lifts jerkily and rather slowly. I have checked and filled the transmission oil. I realise I have not checked the pto since this problem. Somebody must have been here before. I think the external spool valves are working i.e. it sounds like these are under pressure when the lever is moved (there are two horizontal levers under the seat). According to the manual these should only operate with the selector knob pulled out. Low cost answers only please !
gpeters6
02-25-2007 15:27:12
 Re: Ford county 7600 Four hydraulic problems in reply to Alan Bosley, 04-20-2006 11:52:56
I was wondering if you were able to get any parts for your county 7600 if so please post
RodInNS
04-20-2006 14:54:54
Hi Alan,
I'm not sure how that selector valve you have is setup. If you have the factory remotes mounted under the seat that I'm familiar with, then you wouldn't have a selector valve. However, there might be a selector valve to operate a load monitor cylinder, if the tractor has a load monitor. If that's the case, then you would only pull the selector valve out when you have a cylinder attached to the load monitor couplers.
Now to the 3-point problems. I would start by changing the hydraulic filter. There could be a clogged filter, restricting flow. Beyond that, I would suspect either a badly worn pump, or more likely dirt in the control valve or worn internal linkages. There's not going to be anything cheap in there.
So, I'd start at the filter. Then go from there to a pressure gauge in the remotes, and then flow/pressure testing if that doesn't work. I think that tractor should pump about 9.7 US GPM at 2100 rpm, and produce 2500 psi. If that all checks out OK, then I'd probably pull the lift cover and check that over.... I think that would require a cab tilt on that tractor..... Gets nicer all the time....
Rod
Alan Bosley
04-21-2006 11:50:14
 Re: Ford county 7600 Four hydraulic problems in reply to RodInNS, 04-20-2006 14:54:54
Thanks Rod _ I will try the filter and move logically ever hoping not to need the lot stripped out. I will feed back through this forum, the magnitude of my misfortune.
Alan Bosley
05-29-2006 14:33:34
 Re: Ford county 7600 Four hydraulic problems in reply to Alan Bosley, 04-21-2006 11:50:14
I think I have the problem and not what I expected. First there must have been a broken window once upon a time. The rubber boot that keeps the hydraulic control levers and linkage clean was full to solid with broken toughened glass pieces. The boot is solid and the levers are limited in travekl because of this.
Second the rod linking the se;ector lever is broken. Easy to make a new rod. Pulling the broken rod with grips resulted in the three point linkage lifting. Looks much cheaper than I dared hope. Let you know when it is fixed.
