Order Ford 4610 Parts Online
4610 4x4
achad
04-26-2006 18:14:40
Does anyone have a link, or information where to get an axle hub for a 4x4 4610? I believe this tractor was imported from Europe.
RodInNS
04-28-2006 06:12:55
 Re: 4610 4x4 in reply to achad, 04-26-2006 18:14:40
The parts should be available from NewHolland fairly easily, if not rather expensively. That is apt to be the only new source.... Get the axle model number off the axle tag, along with all the other numbers off that tag. Also get the tractor's UNIT number off the tag under the hood, or off the bell housing behind the starter. Just strip the hub down, determine what you need, and buy what you need. You don't buy entire hub assemblies generally, unless you're going the salvage route..... and even then, not too likely. Front hubs are money parts.... Ring and planet gears, along with carriers are the more common replacement parts. Sometimes the swivel casing itself if the bearings have been spun. King pins should be replaceable if they get sloppy..... Dunno just what you need, but entire assemblies get expensive. Also replace any seals that are exposed in the process of what you're doing. HTH.
Rod
dan7840
04-27-2006 12:04:37
There are several different types of 4x4 axle used under the 4610.if you can't get a new one off a dealer, try "robert wraight" he is a ford tractor breaker and we have had several parts off him for our 4610 front axle and got out of trouble
