3 cy, 4 4014c, ford tractor,
Marge Smith
08-18-2001 15:08:35
We have an older ford tractor, it needs steering repair and engine work. We have been looking for a shop and parts manual and can't find one. We have entered this model number at this site to find our model and it doesn't show any manual at all. We took the info off the right side of tractor but it doesn't work. the plate had these numbers too: c 1402134 f3---can anyone help us out? Thanks Dave and Marge
Larry 8N75381
08-19-2001 17:02:21
 Re: 3 cy, 4 4014c, ford tractor, in reply to Marge Smith, 08-18-2001 15:08:35
The numbers 4 4014C may translate into the following; 4 - 4000 series
40 - Utility 1 - diesel 4 - independent 540 PTO C - 8-speed Transmission.
If you have a diesel that has an 8 speed transmission, then those numbers are probably right for your tractor. I would guess that it is the early thousand series which were built from 1965 to 1967.
Check the pictures at the link below. See if one, especially the 4000-5000 1965-1967 looks like yours.
Regards,
Larry
