Order Ford NAA Parts Online
1954 NAA Electrical problem
Russ Kinch
08-19-2001 06:00:09
My 1954 NAA (6 volt) was turning over and eventually starting (especially with a jump from the car). Suddenly it stalled. Afterwards, the solenoid only clicks (like the battery is dead)even while the system is being jumped. I can jump right to the starter and it turns over like crazy, but won't start or even sputter. Any thoughts?
Mike OH
08-19-2001 12:03:35
 Re: 1954 NAA Electrical problem in reply to Russ Kinch, 08-19-2001 06:00:09
Russ - Sounds like your battery needs charging, or replacing if bad. I used to have starting problems with my Jubilee, but no longer since I've gone to heavy gage battery cables, and copper core spark plug wires. Make sure all your connections are clean and tight. Also check to see that your plugs and points are clean and properly gapped at .025". Good luck
